Hello,
I have a VX tarmac rally car and I went in a tarmac rally last weekend and the car went VERY well, but, I barely used 4th let alone 5th using the standard VX gearbox.
So this weekend I found and bought a 2litre box and an 1800 box with the intent to use the final drive (and pinion). The VX has a drive ratio of 3.2, the 2litre approx 3.8 and the 1800 4.1 ( I can't remember the exact numbers).
What is the combined wisdoms view on what I should put in?
The car revs higher than a standard VX (up to 6,500 rpm where I've set the rev limiter which I hit).
I've modelled it using gearbox cascades which while was a neat exercise was hopeless in being helpful
Any help and suggestions would be helpful. I also have a 4.3 final drive which would just be silly.....
Thanks,
Adam
