November 24, 2024, 10:48:24 PM *
Pages: [1] 2
Author Topic: took my car for a drive today...  (Read 11401 times)
raz1966
« on: April 06, 2012, 03:11:23 PM »
got up early and decided to take my beta for a spin, the first time it has been driven since the early 90's....
No MOT/insurance/tax but i live in the middle of nowhere and in 5 years i have never seen a police car around here so i decided to risk it.
i was actually quite shocked at how quick it is, it really goes well,it takes off like a scalded cat when the second choke cuts in.
the engine went well and apart from the exhaust blowing abit all seems well, there seems to be a few fumes coming up from round the back of the engine but it maybe spilt oil burning off (new rocker box gaskets). it did seem to take ages to come off the choke which is a bit of a pain.
steering/suspension was pretty good with no bumps or knocks and it even steered nice and straight. the steering seemed light which was good  considering it has no power steering.
the brakes were not so good, i think there is air in the system as the pedal was not that solid and the brakes seemed poor. i am used to modern cars so i am not sure how good they should be. i will have a look at them in the week and bleed them again, it was a pain to bleed the nipples nearest the front discs as i did not have a cranked 8mm spanner. what is the best order to bleed the brakes?
the speedo was still a bit jerky (new cable fitted) but i can live with it.
apart from that i was well pleased. just need to sort out the above jobs and paint the wheels and fit new tyres and it's time for MOT.
raz1966
« Reply #1 on: April 06, 2012, 03:14:25 PM »
i am running it on super unleaded, do i need any fuel additives?
also does it matter what way the connectors go that go on to the 2 senders on the cylinder head? (near the spark plugs)
i did manage run out of fuel. had to phone her in doors who came with a can of petrol....now i  have to take out for a meal to make up for it!!
« Last Edit: April 06, 2012, 03:16:54 PM by raz1966 » Logged
« Reply #2 on: April 06, 2012, 04:54:15 PM »
One is the water temperature sender for the gauge the other is the switch for the warning light. If you get them on the wrong way round the gauge and light don't work so it's pretty obvious.
I run mine on Super UL without an additive but I will probably start using one when I put the new head on with it's new valves & seats there being no lead 'memory' on them. Possibly it's overkill but I don't enjoy shimming heads that much.
PS Please edit your first post! It's your choice but there are things you don't want to put on a public forum and we certainly don't want to know Smiley
VXdeMayo
« Reply #3 on: April 06, 2012, 09:08:37 PM »
I second that last thought! It's bad enough someone running about "like a scalded cat" with poor brakes, but I would be livid if I was coming the other way in my Beta and got totalled by someone who turned out to have no insurance, tax or MOT.
(Or am out of touch with "modern values" at the wizend old age of 48)!
Words fail me.
Chas,
(VXdeMAYO). Shocked
MattNoVAT
France France
« Reply #4 on: April 06, 2012, 09:53:55 PM »
I always bleed the brake nipple furthest from the master cylinder first.
After a wee bit of use any air in the brake system should gravitate towards the rears.
As for fuel additives I use Millers VSP
1981 2000 Coupe S2/FL
1976 1600 Coupe S1
2007 Ypsilon 1.3 Bi-Colori
« Reply #5 on: April 06, 2012, 10:47:03 PM »
You should get insurance if for no other reason than a small fuel leak could turn the car to a pile of cinders also if the unthinkable happened on a test run could you forgive yourself i'm also an old fart  though........
raz1966
« Reply #6 on: April 07, 2012, 09:49:25 AM »
calm down chaps, it is now fully insured. and i was driving on a private road anyway.
raz1966
« Reply #7 on: April 08, 2012, 05:40:01 PM »
almost finished
raz1966
« Reply #8 on: April 08, 2012, 05:43:24 PM »
inside
raz1966
« Reply #9 on: April 08, 2012, 05:44:52 PM »
i got a new set of wheels to fit and then its going for MOT
raz1966
« Reply #10 on: April 08, 2012, 05:46:58 PM »
total cost so far including puchase price is about £300, it broke down today (no spark), turned out to be the resistor next to the coil, it runs if i bypass the resistor, do i need it?
raz1966
« Reply #11 on: April 08, 2012, 05:48:38 PM »
engine bay
« Reply #12 on: April 08, 2012, 06:12:09 PM »
The resistor is normally used in series with the coil for normal running with the nominal voltage being 12V. When starting the voltage is normally much less, so the resistor is shorted during this period to give a better spark. So in answer, yes you will be overloading the coil which will eventually fail if subjected to too high a voltage. I have not checked the wiring diagrams, so happy if someone wants to correct me.
MattNoVAT
France France
« Reply #13 on: April 08, 2012, 07:38:01 PM »
Looks good Raz.
Nice to see another on the road :-)
1976 1600 Coupe S1
thecolonel
« Reply #14 on: April 08, 2012, 08:06:51 PM »
Cars with coil & resistor use a 9volt coil,
during starter operation 12 volts is fed
from starter solenoid direct to coil giving
it a short boost, during normal running
coil is powered through resistor which
drops voltage to 9 volts.
« Reply #15 on: April 08, 2012, 09:04:56 PM »
It's called a ballast resistor and you'll need another.
slowe
« Reply #16 on: April 08, 2012, 09:52:00 PM »
Looking very nice Raz
thecolonel
« Reply #17 on: April 08, 2012, 10:13:23 PM »
The old one will have a value written on it,
just replace like for like or check the wiring
diagram.
« Reply #18 on: April 09, 2012, 08:32:38 AM »
A lot of car for the money as they say!
raz1966
« Reply #19 on: April 09, 2012, 03:30:21 PM »
the new coil came with a resistor, but i cant find the old one, i changed the new coil for my old one and it runs fine. i am worried that a 32 year old coil will fail soon so i may still get a new coil. does anyone know what value the resistor should be?
Pages: [1] 2
