November 24, 2024, 09:45:05 PM *
Author Topic: sump plug question  (Read 2891 times)
raz1966
« on: March 02, 2012, 06:27:51 PM »
i am confused about my sump plug, if i screw it in all the way in just falls through the hole in to the bottom of the sump, i shall not be doing that again as it took me 3 hours and very sore fingers to get the bloody sump off (thanks to hf stuart for advice), and i still get get the anti rollbar back on.
the threads in the sump are fine and the ones on the plug look ok, i guess some thing is bent in the sump as i am sure the plug used to tighten up. i did not use any thread tape. but i am not sure if it would help. if i use a bolt type plug that would work but i don't know what size the thread is. any one else had this problem?
on the plus side i got all the brake calipers off in about 20 minutes and the brakes are much better than i thought, all 4 discs are ok and even the rubber hoses seems absolutely fine, i just am just going to put new seals in the calipers (a couple seemed to be leaking a bit) and fit new pads. the suspension looks ok as well with no leaks and all the bushes seem fine.
more good news...the old guy who had the car before me (he had it for 28 years) found all the paper work, i now have the original service book (all stamped by local lancia dealer),owners manual and even the 6 year  anti corrosion booklet.
raz1966
« Reply #1 on: March 02, 2012, 06:33:13 PM »
where can i get the cotter pins that hold the wedges in the calipers?
and the small springs which go on the brake pads?
« Last Edit: March 02, 2012, 06:57:47 PM by raz1966 » Logged
« Reply #2 on: March 05, 2012, 06:42:23 PM »
Raz,
I have both the wedges and the pins that stop the wedges from coming adrift.
PM me - there are two sizes of wedge.
« Reply #3 on: March 05, 2012, 09:58:52 PM »
My sump plug is threaded all the way up and would screw right into the sump if turned too far. I assume this is the result of previous over tightening. I only tighten it using the centre of the wrench with the plug tool fitted and stop as soon as resistance is felt. It's not a perfect seal but doesn't leak noticeably.
steptoe
« Reply #4 on: March 06, 2012, 03:49:32 PM »
I have new original FIAT/Lancia sump nuts in stock if anyone wants one pm me!
RUST RUST RUST
SQUEAK RATTLE SQUEAK
RUST RUST RUST
steptoe
« Reply #5 on: March 06, 2012, 05:15:05 PM »
All sold. Should I find anymore I will post here.
RUST RUST RUST
RUST RUST RUST
raz1966
« Reply #6 on: March 07, 2012, 06:53:50 PM »
i have got one now, problem sorted
