November 23, 2024, 10:15:34 AM *
Author Topic: rear suspension bushes  (Read 3707 times)
thecolonel
« on: February 14, 2012, 06:31:59 PM »
Does anyone have the original part numbers
For all the rear suspension bushes please ?
Links, anti-roll bar etc.
Geoff
MattNoVAT
France France
« Reply #1 on: February 14, 2012, 08:15:53 PM »
82320406 is the p/n of the bush (silent block) - same for both ends of the transverse link arms.
Be careful with these as they should be 30mm diameter and later Lancias (Delta) used 32 mm - I know because I was given a set of 4 years ago and thought I'd use them only to find they are 2mm too big.
But then if a Gamma uses slightly bigger 32mm bushes - I have a set of 4 :-)
1981 2000 Coupe S2/FL
1976 1600 Coupe S1
2007 Ypsilon 1.3 Bi-Colori
thecolonel
« Reply #2 on: February 14, 2012, 10:26:31 PM »
That's the same number as the gamma bush.
The other one is the anti-roll bar bush In the
base of the hub .
Hopefully it's the same as the Beta.
thecolonel
« Reply #3 on: February 14, 2012, 10:54:02 PM »
The other bush number is 82315794
Geoff
MattNoVAT
France France
« Reply #4 on: February 14, 2012, 11:01:17 PM »
That might explain it as the ARB to base of hub on a S1 is a different design to the later cars.
Thanks Geoff
1976 1600 Coupe S1
