November 25, 2024, 12:38:12 PM *
Author Topic: carb info needed  (Read 7461 times)
raz1966
« on: February 12, 2012, 02:37:18 PM »
does anyone know what order the 4 jets go in on a 34 datr carb? i took mine out to clean them and left them on my bench in the correct order but they got mixed up
« Reply #1 on: February 12, 2012, 03:52:36 PM »
I have checked a 34 I have on the shelf.
From the thermostatic side (water inlet/outlet)  80 / 150 / 120 / 50
Obviously there is no guarantee that this old carb has not been messed around with in the past.
raz1966
« Reply #2 on: February 12, 2012, 05:52:24 PM »
so is the 80 jet nearest the automatic choke? does any one know what the float hight should be and how do i set it?
« Reply #3 on: February 12, 2012, 06:20:12 PM »
I would look but I managed to fall off a ladder yesterday (due to my own stupidity) not from a great height but I've done my back in due to landing heavily ( probably too many pies....). Further than that I'd been cleaning two expansion tanks and was too injured at the time to remove them from the sink........you can guess what the wife said when she got home Angry and I always thought that was what kitchens were for?? And normally what she doesn't see she doesn't worry about!
Anyway hopefully I'll check the specs in a day or so for you when I creak a bit less
« Reply #4 on: February 12, 2012, 06:31:03 PM »
Yes, 80 nearest the inlet/outlet for the auto choke.
raz1966
« Reply #5 on: February 14, 2012, 03:30:40 PM »
i have cleaned the carb out, and the jets are in the correct positions, but it still runs very rich, i put £5 worth of fuel in it and it used the lot in about 10 minutes whilst i was messing with the carb....anyone got any ideas?
raz1966
« Reply #6 on: February 14, 2012, 04:53:39 PM »
my jets are 80/240/170/50 (80 nearest choke), i swapped the float for another one but no difference.
« Reply #7 on: February 14, 2012, 05:28:47 PM »
Do you have a set of original 150 / 120 main jets?  you can test with?
I'll check what jets are in my S2/FL tonight as I know they have standard jets.
Have you tried adjusting the mixture?  I'm sure there is a small mixture screw (going from memory)
raz1966
« Reply #8 on: February 14, 2012, 07:01:20 PM »
i got 3 carbs and they all have the same size jets, i am fairly sure the jets i have are correct for a 2 litre engine, the only adjustment i can see is a small screw near the base of the carb, i am not sure how to set this up, do  i screw it all the way in and then out a certain number of turns ? (this how most motorbike carbs are set up)
« Reply #9 on: February 14, 2012, 08:17:58 PM »
That method sounds familiar, I think its covered in the Haynes book of lies
« Reply #10 on: February 14, 2012, 11:10:41 PM »
2000 datr carb 1st (2nd) choke  main jet 120 (150) air corrector 170 (240) emulsion tube f30 (f30) idle jet 50 (80) idling air jet 110 (70) pump jet 50 (na)  super feed jet na (110) super feed mixture jet na (200)
needle valve 175
float level with gasket 7mm +/- 0.25 this is measured by holding the top cover of the carb turned vertically and with the float hanging down distance between top of float arm and the carb top
hope I've transcribed those right! Can't say that i really understand carbs so complicated and full of mystery
I'd suspect maladjusted or faulty auto choke and/or float level setting and/or air leak in floats themselves and/or sticking needle valve
« Last Edit: February 15, 2012, 10:27:26 AM by rossocorsa » Logged
« Reply #11 on: February 14, 2012, 11:20:45 PM »
this wouldn't make such a huge difference to the fuel consumption however to set mixture I'd recommend using a gunson colortune dead easy that way and quite accurate the turn in /out X number of turns method isn't accurate enough
« Last Edit: February 15, 2012, 10:28:51 AM by rossocorsa » Logged
raz1966
« Reply #12 on: February 15, 2012, 05:45:38 PM »
there are lots of gunson kits on ebay, what size is the plug thread on a 2000 beta?
raz1966
« Reply #13 on: February 15, 2012, 09:43:44 PM »
i am fairly certain there is something wrong with my carb, i have a couple of spares so i think i shall built another one and try that.
« Reply #14 on: February 15, 2012, 11:36:37 PM »
I think its 14mm
raz1966
« Reply #15 on: February 16, 2012, 04:37:22 PM »
i am still not sure of the order of the jets, guess it will be trial and error
« Reply #16 on: February 16, 2012, 08:04:09 PM »
I'll see what tech diagrams I have but I'm too busy with other stuff this week/weekend will try to find something early next week
Alan
Ammy
« Reply #17 on: February 16, 2012, 10:12:50 PM »
I have original tech. sheet in Italian but still useable.  Problem is I don't know how to attach a copy to this message
« Reply #18 on: February 17, 2012, 12:35:49 PM »
easiest to upload it to lancisti http://www.lancisti.net/forum/downloads.php?do=cat&id=3 then post the link here
