November 21, 2024, 12:39:22 PM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
: Looking for Lancia Beta parts:
www.lanciabetaparts.co.uk
Home
Help
Contact Admin
Search
Calendar
Gallery
Articles
Login
Register
Keeping your Beta on the road
Owners Useful Tips
Tips
Pages: [
1
« previous
next »
Author
Topic: Tips (Read 5632 times)
tonylanciabeta
Tips
on:
November 01, 2008, 03:32:32 PM »
From AlecD.
Wipers too slow-
Try replacing its fuse as old ones can change their resistance.
Bad earths- Replace the spider connector below the headlight mounts with one similar to the one used behind the dash. Keep it clean!
Heater fan- If you turn on your heater and it causes the dash lights to turn off, a loose fuse could have caused the the plastic body of the fuse to melt.
Indicators running too fast.
From Markwast. Firstly check that all are the bulbs are working. If one isn't then check the earths. Once they are clean but there is still a bulb not working, dismantle each block connector and clean each spade terminal. Once i had done this all my indiactor faults were cured and i have had no further problems.
Gear Linkage
From Markwast - When installing a new linkage bush set, before you install the metal pivots, soften the bushes in boiling water. Do this also when pushing them into place on the linkage arms.
Door Car Clips
From TonyLanciaBeta - If you want new clips for your door cards etc, Tony got some Delta ones from his local Fiat dealer and they fit really well and dont damage the cards.
Keys- From Tony Brown - Need a set of keys = including that high security one for the door/boot locks? I can recommend John Richard of Keys Unlimited. He not only supplies the blanks but will cut the keys to a supplied code as well. Fast response and good prices. 0151 342 2318/4074.
Another quick tip I have come across during my restoration.
I was getting terrible noise and vibration that turned out to be the engine shock absorber. When I took it off, luckily the damper itself was still ok (not seized or slack) but the rubber bush at the lower end was completely shot so effectively, the damper rod was just banging against the mounting bolt all the time.
A couple of measurements showed that I needed a bush with an OD of 25mm and ID of 10mm.
A trip to my local classic car spares shop provided me with a Triumph Spitfire rear spring eye bush at a cost of £5.30.
This is too long and needs to be cut down and has a diameter which is fractionally too big (no metric fittings on the Spitfire) but 10 mins with a file and it was a perfect fit.
I pressed the bush into the damper lower eye in the vice after removing the old outer sleeve with a hacksaw and the car is a completely different beast. Smooth and quiet(ish).
I hope this might help somebody and it is certainly a lot easier than trying to find a replacement damper.
Cheers.
Ian.
Last Edit: November 30, 2008, 07:13:48 PM by tonylanciabeta
Pages: [
1
« previous
next »
Please select a destination:
WELCOME TO THE LANCIA BETA FORUM - READ THIS FIRST
=> Welcome Message
=> Forum Rules, FAQs and basic user guides
=> Feedback and recomendations for the forum
General Category
=> New members
=> Members Cars
=> Back in the day
=> General Discussion
=> Group Buys
=> Off Topic
=> Betas in the Press
=> Events 2024
=> Events 2025
Technical stuff
=> Part Number Requests
=> Engine
=> Transmission
=> Fuel System Carb
=> Fuel System Injection
=> Fuel System VX
=> Heating/Cooling
=> Exhaust System
=> Ignition
=> Brakes
=> Electrical
=> Suspension
=> Steering
=> Wheels/Tyres
=> Interior
=> Manuals / Spec sheets
=> Body
=> Tuning and competition
=> Specialist Lancia Garages
=> Lancia Friendly Companies
=> Owners Useful Tips
Classifieds: Cars/Parts for sale/wanted
=> Collectables and Memorabelia
Reproduced Parts Information
=> What parts would you like reproduced?
Previous years Events
=> Events 2023
=> Events 2022
=> Events 2021
=> Events 2020
=> Events 2019
=> Events 2018
=> Events 2017
=> Events 2016
=> Events 2015
=> Events 2014
=> Events 2013
=> Events 2012
=> Events 2011
=> Events 2010
Archive from MSN Forum 2002 - 2008
=> Events 2008
=> Archive from MSN Forum 2008
=> Archive from MSN Forum 2007
=> Archive from MSN Forum 2006
=> Archive from MSN Forum 2005
=> Archive from MSN Forum 2004
=> Archive from MSN Forum 2002 - 2003
Loading...
