November 25, 2024, 05:48:03 PM *
Author Topic: non starting problem  (Read 7439 times)
rodney3010
« on: May 14, 2011, 09:20:18 PM »
I was hoping somebody might have an idea what I should look at next. Story so far - Spider 2000 not run for a few months. Has a new battery, leads, plugs, cap, rotor arm and coil. Now getting nice big spark at plug. However, still no sigh nof starting.
I don't seem to be getting a lot of fuel into the carb. The fuel filter (new - fitted right way round), doesn't get full. Would I be right in thinking might be fuel pump problem?
Any suggestions of what to look at next would be much appreciated.
Rodders
« Reply #1 on: May 14, 2011, 09:50:48 PM »
From what you have described the mechanical fuel pump would be what I renew next.
« Reply #2 on: May 14, 2011, 09:54:46 PM »
To test : Have you tried dropping a bit of fuel straight down the carb to see if there is any sign of the engine trying to fire up, if it does try to start then it's most likely the fuel pump is faulty.
rodney3010
« Reply #3 on: May 15, 2011, 09:22:46 AM »
Cheers Matt, thats next course of action then.
Anybody know best place to buy a fuel pump (Betaboyz have sold out)?
Rodders
« Reply #4 on: May 15, 2011, 01:06:23 PM »
They are usually on eBay UK, if not then they are definitely available on eBay Italy.
Try eBay UK item 220511738845
rodney3010
« Reply #5 on: May 15, 2011, 09:14:00 PM »
Unfortunately, work laptop so e-bay barred. If anyone can help, much appreciated
Rodders
« Reply #6 on: May 15, 2011, 10:50:53 PM »
I did have one, maybe two brand new ones, I'm not sure if I still have them couldn't sell them on ebay for 99p (!!) so they might have ended up in the bin with a lot of other Lancia bits that were getting under my feet, I will try to check tomorrow night
« Reply #7 on: May 16, 2011, 08:16:36 AM »
I might have a used one, I'll check tonight - at worst it can be a temp workaround or determine if its actually the pump thats at fault.
If it turns out the pump is at fault then PM me and I'll get one off ebay for you and send it up to you.
JoeBeta
« Reply #8 on: May 16, 2011, 10:52:20 AM »
Have you tried taking the fuel pipe off just before the filter and turning it over to see if petrol pumps out??
Be careful of Fuel Pumps on Ebay...  I bought one and the top of the pump needs to be cut away to fit under the manifold (on my 1.6 coupe anyway) I bought one which wouldn't tuck in under the manifold???
Joe
« Reply #9 on: May 16, 2011, 10:40:19 PM »
well I spent an hour going through my parts stash and getting oil on my trousers (= trouble from swmbo) to only to find that I don't seem to have those fuel pumps any more, it did remind me of what I do have I am constantly forgetting what parts I have and which parts I still need to trawl eBay for
rodney3010
« Reply #10 on: May 17, 2011, 08:42:31 AM »
Many thanks for looking anyway - hope the trouble wasn't too bad!
« Reply #11 on: May 17, 2011, 11:52:30 AM »
no luckily they were quite old trousers so amazingly I got away with it  Grin
