November 26, 2024, 12:51:37 AM *
Pages: 1 2 [3]
Author Topic: HPE windscreen  (Read 20056 times)
0 Members and 18 Guests are viewing this topic.
VXdeMayo
« Reply #40 on: July 24, 2012, 11:33:57 AM »
Dear Andrew,
I am so glad that you "can see your way clear" through this brain numbing saga. I will now hold onto my old spare screen for now (slight misting at the corners or not), given your bad experience.
There is a slight ironic twist to this windscreen saga: ---------- MY middle name is Pilkington! Long story, not for now!
PS: Seeing you have demonstrated loads of determined tenacity,  how would you feel about dealing with my frozen nipples on my brake calipers?
I have cleaned the calipers throughly, soaked them in penetrating oil for days, repeated when dry and so on. I have applied heat from a butane gaz torch for 5 minutes or more on three occasions to enable the differing rates of expansion to kick in (steel verse alloy etc), to no avail
Of the four only ONE has budged! I have not yet snapped any off but it could happen soon.
Suggestions on a postcard please.
Well done,
Chas and Anne. Smiley
spud
« Reply #41 on: July 24, 2012, 02:03:50 PM »
...I have applied heat from a butane gaz torch for 5 minutes or more on three occasions to enable the differing rates of expansion to kick in (steel verse alloy etc), to no avail...Chas and Anne. Smiley
I was told years ago not to apply heat but to freeze them... my local engineer has freed a few over the years for me and I'm sure that's what he does. Anyone else got an opinion?
Alternatively, sod the nipples and use these:
http://www.ebay.co.uk/itm/M10-x-1-25-banjo-bolt-with-bleed-screw-nipple-/160724310059?pt=UK_Motorcycle_Parts&hash=item256bea582b
Work perfectly. My car has six.
Andrew.
Montecarlo S2 Spyder
HPE VX
Y10 GTi.e. x2
Various other non Lancia projects...
« Reply #42 on: July 24, 2012, 05:27:47 PM »
Hi Andrew
Now that looks like a sensible solution, I assume you have to be careful to orientate the caliper so the air from the piston vents as well?
« Reply #43 on: July 24, 2012, 05:53:38 PM »
These bleed screws in the bolts are high enough to work perfectly and were made for motorbikes which also have bleed screws seize in place. They are a great solution for Beta owners.
MattNoVAT
France France
« Reply #44 on: July 24, 2012, 07:00:42 PM »
Mark W sells these and I have used a set but not on a Beta but pretty much identical brake calipers, they work brilliantly !
1981 2000 Coupe S2/FL
1976 1600 Coupe S1
2007 Ypsilon 1.3 Bi-Colori
Pages: 1 2 [3]
