December 30, 2024, 11:44:10 PM *
Author Topic: Fiat 132 2.0L Cams for 1600 Beta coupe?  (Read 3340 times)
betasulo
Full Member
« on: April 02, 2011, 02:40:25 AM »
Hi All,
Is it possible to do the above and will it help?. Are the Fiat cams the same as on a 2.0L Beta?
Sulo
75coupe
1975 Beta coupe 2L
« Reply #1 on: May 20, 2011, 11:29:54 PM »
Hi, the cams will fit no problem but they have different timing and lift to beta cams. Is your 1600 a 1585cc or an early 1592cc? The 2l fiat cams are also timed differently to beta 2l cams.
Beta cam timing:
2L: 13/45/49/9 With 9.9 mm. 9.4 mm lift on 1592cc. 1585cc: 17/37/48/6 with 9.4 mm lift
Fiat 131 2L: 5/53/53/5 with 9.9 mm lift.
Fiat 132 2L: 15/55/57/13 with 9.9 mm lift.
There are different cam pulley markings/offsets too which is how the timing is altered on some models.
Confused yet? Is there a specific reason you want to swap cams?
Guy Croft is a very good source of info on camshafts and the twin cam engine.  www.guycroft.com
Regards Ian
betasulo
Full Member
« Reply #2 on: May 25, 2011, 09:51:00 AM »
Hi Ian,
Thanks for all this info.
The plan is to up the performance of my car which is at this time being restored. I hope to get twin Weber carbs and was told the Beta 2.0L cams are the way to go.
I still have a good chance of getting 2.0L Fiat cams and was wondering if it would be the same as the Beta ones.
I will also check which engine I have.
Kind regards
Sulo
75coupe
1975 Beta coupe 2L
« Reply #3 on: May 25, 2011, 10:25:05 AM »
Yes you will get a small increase in power, may be a few BHP, but don't expect miracles from swapping std type cams. the twin carbs are definately a good move, worth about 10 BHP+ on their own if sidedraughts. Head mods and increased compression are the way to go too. I run almost 11:1 CR on my 2 litre still using 98 octane pump fuel.
It may be worth finding a 2 litre motor if you want serious power - just remember you will get greater returns from this motor than the 1600 for the same money spent, and a 2 litre with twin carbs, compression and cams revs just as well as a mildy tweeked 1600 - my 2 litre revs to 7500 no problem!
You can see what mods I have done in the tuning & competition section under 2L uprated engine build.
