November 23, 2024, 09:03:52 PM *
Author Topic: HPE/Coupe/Saloon shocks  (Read 7704 times)
spud
« on: January 18, 2011, 05:11:50 PM »
Hi all,
I'm sure I've read somewhere that the front shocks of the HPE/Coupe are different from the saloon. Is this correct? Monroe list them as MR833 for all models... Huh?
Are there any inserts available anywhere (apart from the spax) to fit the HPE?
Andrew.
Montecarlo S2 Spyder
HPE VX
Y10 GTi.e. x2
Various other non Lancia projects...
« Reply #1 on: January 18, 2011, 11:21:21 PM »
The front springs are different for sure - I thought the shocks were the same for all on the front.
spud
« Reply #2 on: January 19, 2011, 10:56:53 AM »
Ah, maybe just the springs then... I knew something was different...
Andrew.
HPE VX
Y10 GTi.e. x2
markwast
« Reply #3 on: January 19, 2011, 07:22:56 PM »
Hi, both struts (shocks) and springs are different.
Springs are taller .
Shocks are taller and thicker .
spud
« Reply #4 on: January 19, 2011, 10:09:27 PM »
So Monroe must have it wrong then...? They list that part number as fitting all Betas except the 1800 for some strange reason.  Huh?
Andrew.
HPE VX
Y10 GTi.e. x2
« Reply #5 on: January 19, 2011, 11:36:11 PM »
Thanks for clarifying Mark.
You wouldn't happen to have the measurements of either so we can check which is which ?
MattNoVAT
France France
« Reply #6 on: January 23, 2011, 04:43:31 PM »
Hi Stuart,
Have a look on the history section of the forum - when it was run the Microsoft forum service, I had Berlina/Sedan front shocks on my Coupe and it sat "high" at the front.  I put a new set of Coupe shocks & springs on and that sorted the issue, from memory I had all the measurements included in that thread - unsprung spring height etc.
Cant remember off top of my head now (an age thing!)
1981 2000 Coupe S2/FL
1976 1600 Coupe S1
2007 Ypsilon 1.3 Bi-Colori
« Reply #7 on: January 23, 2011, 11:00:02 PM »
Matt,
Ahem.... I know,  I was the one that suggested that you had the wrong springs on  Wink
But no dimensions for the shocks that I could find. Not a problem I've got a good known Spider / Coupe set so I'll just comare them to the ones currently on the car, I already know the springs are wrong so it will only take a moment while I'm taking them off.
Stuart
« Reply #8 on: January 24, 2011, 08:40:30 AM »
This topic was covered more recently in great detail, including some photo's with measurements andpictures of 'The Colonel's' adapted Subaru struts for his Gamma. Should be findable in the suspension section?
MattNoVAT
France France
« Reply #9 on: January 24, 2011, 09:14:03 AM »
See I'm older and more senile than I first thought!
I do recall that when I measured the Sedan and Coupe springs when assembled rready to go on the car they measured up pretty much identical, but when on the car it sat higher on Sedan springs.
1976 1600 Coupe S1
markwast
« Reply #10 on: January 24, 2011, 10:30:17 AM »
Hi Stuart
PM me and ill see if i get the measurements for you.
Which details would you like?
Mark
« Reply #11 on: February 03, 2011, 08:34:31 PM »
Mark,
PM sent - any luck with the measurements? Particularly the insert lenghts.
Stuart
spud
« Reply #12 on: March 17, 2011, 11:00:14 PM »
If anyone can post here the size difference between the inserts for the saloon and the coupe/hpe I would appreciate it. Are the saloon inserts bigger? Longer? Thicker? Would the saloon insert fit in an hpe strut? The previous posts don't make it clear...
Also- I'm no suspension expert so bear with me...
The ride height of the car is determined by the springs. Correct?
So just because the saloon shock absorber insert may be longer it shouldn't affect the ride height of an hpe. Correct?
If so, the limitations of fitting a saloon insert (which are available) into an hpe strut body are: The diameter of the insert body and the length of the insert body- whether it would physically fit into the hpe strut housing.
So if I'm correct in my thinking I'm now back to my fist point here: Anyone know the measurements...?
Andrew.
HPE VX
Y10 GTi.e. x2
spud
« Reply #13 on: August 15, 2011, 11:46:04 PM »
 Huh?
Anyone?
Andrew.
HPE VX
Y10 GTi.e. x2
MattNoVAT
France France
« Reply #14 on: August 16, 2011, 06:53:12 AM »
I have just rebuilt my front coupe suspension with new inserts which came from Mark W.
I know he's quite busy so am sure he'll get back to you soon, although it's probably best to email him direct.
Have a look at the 1600 coupe restoration thread under Members Cars.  Or PM me.
1976 1600 Coupe S1
