Title: new carbs Post by: thecolonel on June 30, 2010, 10:38:41 PM As a few of you will know I drive Gammas
anyway, I've sorted the suspension, seats, bodywork and now I'm after POWER in this vein I've thought about DCNF carbs but they don't like sitting sideways that leaves IDF's but they are extremely rare and quite expensive, so I've been looking at alternatives and I've come across a couple of race forums that are quite keen on Keihin or Mikuni now these are bike carburetors and aparently work very well with little or no adjustment only a couple of jets and enable large volumes of air to be drawn into the engine. So any Beta drivers that also ride bikes and have experience of these carbs. I will add that I was thinking of a set of 4 carbs from a 1000 cc bike then simply modify my manidfold and attach 1 per cylinder. Geoff Title: Re: new carbs Post by: Neil-yaj396 on July 01, 2010, 07:34:16 AM I think Keihin carbs are made by Honda (my Triumph Acclaim had apair of them!). Have to say that I can't see bike carbs having a sufficient throat for Gamma cylinders, weren't they the biggest in a production car at the time?
Title: Re: new carbs Post by: thecolonel on July 01, 2010, 10:55:50 AM must admit I thought the same but at the moment I'm running an ADL38 which has quite
small chokes in comparrison to the bike carbs, going from two throats to 4 should be an improvement although I can't be sure until I try it, hence the question. Geoff Title: Re: new carbs Post by: Thotos on July 01, 2010, 12:34:05 PM This is what you need Geoff ;D
(http://www.gammaconsortium.com/images/webers.jpg) Start looking in scrapyards for an old Alfasud 1.5 Ti or even better Alfa 33 Cloverleaf (non 16V). And you'll need a VW Beetle throttle linkage ;) Title: Re: new carbs Post by: thecolonel on July 01, 2010, 04:09:14 PM I agree Theo, but, having searched for some time, they are either ridiculously expensive
or require a full rebuild, whereas the bike carbs sell for about £40.00 for good s/hand ones Title: Re: new carbs Post by: thecolonel on July 13, 2010, 10:16:23 PM Well the new carbs are en-route
4 Mikuni 45 degree angle 39mm slide throats same size as the inlet ports may have to use them as throttle bodies with injectors as it is possible they may be too vicious, from what I've learnt they're a bit all or nothing. still could be a bit of fun, alternative is use two of them as carbs attached to a supercharger Geoff |
