Technical stuff => Brakes => Topic started by: gjanssen on February 06, 2025, 03:43:35 PM
Title: HPE VX Engine cuts out when braking
Post by: gjanssen on February 06, 2025, 03:43:35 PM
Hi all,
After 29 years of sleeping in a garage box a the Lancia has been inspected and admitted to public roads again !
The garage has spent many hours to make everything technically ready.
The only problem now is that when I press the brake pedal hard, the engine cuts out.
The brake pedal is also not always equally hard. Sometimes I have to pump a bit to be able to put full pressure on the brakes. And as I said, the engine often stops.
I suspect there is something wrong with a vacuum hose. Is this easy to test?
(https://www.betaboyz.myzen.co.uk/forum/index.php?action-gallery;sa=view&id=566)
Kind regards,
Gerrit
Title: Re: HPE VX Engine cuts out when braking
Post by: gjanssen on February 06, 2025, 03:48:51 PM
And a nice picture..... :-)
(http://www.betaboyz.myzen.co.uk/forum/gallery/3513_06_02_25_2_36_22.jpeg)
Post by: JohnFol on February 08, 2025, 12:30:15 AM
Hi Gerrit, I can see you've not had a reply so just giving this a bump.
I'm far from an expert but I had similar on my Spyder. combination of idle set too low and a manifold leak.
The way I found the manifold leak was to spray something flammable around the inlet gasket with engine running. If engine picks up, the spray has been sucked in where it shouldn't.
Post by: Nigel on February 08, 2025, 11:24:20 PM
Hi Gerrit,
Assuming it's running and pulling normal power, perhaps the
brake servo is leaking air/vacuum?
I say this because applying the brakes is actioning the servo, before that
there is no fault apparent.
There could well be a leak elsewhere as John has suggested, but that type
of leak would not change when the brakes are used.
I suggest you try blanking off the pipe to the servo, and driving it.
Obviously extreme caution needed as you'll have a very heavy brake pedal,
but if it doesn't stall you'll have an answer.
Go carefully
Post by: gjanssen on February 20, 2025, 06:47:45 PM
Thank you both for your answers!
The problem was a vacuum leak between the master brake cylinder and the servo.
Checking cables: no problem.
While the engine was idling, disconnecting the vacuum hose from the carburetor resulted in the engine stalling immediately.
When the pedal was pressed, a small hissing noice was coming from the servo.
Afther that, i noticed one of the 2 bolts, were the master brake sylinder is connected to the servo was not tighten properly and when my son presses the brake, I noticed the master brake cylinder moves one millimeter forward
Just after tighten it, problem is solved.
