Title: Engine makes noise after overhaul Post by: Gerke123 on August 17, 2024, 05:43:10 PM Hello all,
We recently had the engine overhauled and rebuild it completely, Both the head and the engine block has been rebuild by professionals, yet when we first started the car, it was like starting an MK1 Golf diesel. We have double checked everything, but i doubt this is how the car is supposed to run after a rebuild. We have checked the timing and ignition, and those were all on point. The valve clearing has also been done professionally by a company. The oil pump is working perfectly too. The engine has now run for 30 seconds, and we dont have the courage to let it run any longer. Does anyone else have this happen to them before when starting a recently rebuild engine? And what can we do to possibly fix this without taking the engine out of the car again? -Gerke Title: Re: Engine makes noise after overhaul Post by: SanRemo78 on August 17, 2024, 06:00:43 PM I'd be checking valve clearances first. They may need re-shimming to get clearances right.
Title: Re: Engine makes noise after overhaul Post by: peteracs on August 17, 2024, 09:46:14 PM I think you need to be a bit more specific on what you mean by rebuilt……
First thing did you spin up the oil pump before starting or turning over the engine to confirm oil pressure? When it was rebuilt did they use engine assembly lube to the crank, rods etc? Did you check that the engine would turn over easily by hand without plugs installed? Have you checked the cam belt timing before starting? Just a few thoughts …. Peter Title: Re: Engine makes noise after overhaul Post by: Gerke123 on August 18, 2024, 09:15:47 AM Hello Peter,
Yes, we can check all that off. However, there was a point when turning the engine by hand was a bit more difficult. But after two full turns this went well. And on the starter motor without spark plugs it ran like crazy without any camming noise. Maybe the valve clearance could have something in it. But I had this done by a professional........ Title: Re: Engine makes noise after overhaul Post by: stableblock on August 18, 2024, 09:55:29 AM Is the noise metallic? Have you checked the exhaust manifold gaskets are correctly fitted?
Title: Re: Engine makes noise after overhaul Post by: Gerke123 on August 18, 2024, 12:59:30 PM Is the noise metallic? Have you checked the exhaust manifold gaskets are correctly fitted? What do you mean? I just looked at my engine reserve parts, but you can only put the gasket on one way and they are optically the same on both sides. It is a metallic popping sound, just like a diesel engine. can you explain that? Title: Re: Engine makes noise after overhaul Post by: rossocorsa on August 18, 2024, 07:21:54 PM Just a wild suggestion, I'm just wondering about cam timing, is there any chance that the cam pulleys are swapped over? This might make the timing marks out. I'm not sure but I think they will fit either camshaft? I think that exhaust pulley has lip to the front and inlet to the back on early engine???
As I said just a wild guess, I'm no engineer and struggle with stuff. Title: Re: Engine makes noise after overhaul Post by: HFStuart on August 18, 2024, 08:11:10 PM Aux driveshaft hitting the crank? This can happen if it's not positioned correctly.
Title: Re: Engine makes noise after overhaul Post by: Nigel on August 18, 2024, 10:07:03 PM Hi Gerke,
I assume you are seeing healthy oil pressure and you've double-checked the camshaft timing including the aux shaft. I also assume you've re-checked the valve clearances. With all this established it doesn't sound like it would damage it to run it again. I don't think you can post an audio on here, but if you or someone in your house has a suitable media account, maybe facebook? post a clip of it running and share the link here. Nigel Title: Re: Engine makes noise after overhaul Post by: capriblu on August 18, 2024, 10:07:20 PM Aux driveshaft hitting the crank? This can happen if it's not positioned correctly. That would be the first thing I would be checking. Title: Re: Engine makes noise after overhaul Post by: Gerke123 on August 19, 2024, 11:08:06 AM Just a wild suggestion, I'm just wondering about cam timing, is there any chance that the cam pulleys are swapped over? This might make the timing marks out. I'm not sure but I think they will fit either camshaft? I think that exhaust pulley has lip to the front and inlet to the back on early engine??? As I said just a wild guess, I'm no engineer and struggle with stuff. After this question something started to bother me. Checked this morning but luckily they are placed correctly. Title: Re: Engine makes noise after overhaul Post by: Gerke123 on August 19, 2024, 11:14:38 AM Hi Gerke, I assume you are seeing healthy oil pressure and you've double-checked the camshaft timing including the aux shaft. I also assume you've re-checked the valve clearances. With all this established it doesn't sound like it would damage it to run it again. I don't think you can post an audio on here, but if you or someone in your house has a suitable media account, maybe facebook? post a clip of it running and share the link here. Nigel Hello Nigel, The Aux shaft could be 1 notch off. I'll see if I can change this. If this is not the solution, I will see if I can load a video. The aux axis is often mentioned here, so let's move on first. I'll keep you informed. Title: Re: Engine makes noise after overhaul Post by: Gerke123 on August 19, 2024, 03:54:12 PM Hello all,
I recorded a video of the sound coming out of the engine. Here's the link to the video: https://streamable.com/f66hib -Gerke Title: Re: Engine makes noise after overhaul Post by: Nigel on August 19, 2024, 09:02:16 PM Hi Gerke,
That helps alot. To me that sounds like valve clearances too wide. However there could be an issue with oil not reaching the top of the engine. Suggest you remove the 2 cam covers to see if it's well lubed inside. Did you check the valve clearances already? Nigel Title: Re: Engine makes noise after overhaul Post by: HFStuart on August 19, 2024, 10:23:53 PM I think we can agree that sounds bloody awful. Unless it's something obvious like valve clearances or the aux shaft I think you have to take the head off.
To me it sounds really piston like maybe even hitting the head but only way to be sure is to strip it. Title: Re: Engine makes noise after overhaul Post by: peteracs on August 19, 2024, 10:45:49 PM Hi
I would check the valve clearances regardless of what you have been told, sounds very much like may be too wide to me. As with Nigel also check you are getting plenty of top end lubrication as well. Checking them is a pretty easy thing to do. Peter Title: Re: Engine makes noise after overhaul Post by: Gerke123 on August 20, 2024, 08:13:25 AM Hello,
Thanks for the replies. We have removed the cam covers and the oil is very much present at the top of the engine. As for the valve clearences, we will have to talk to the guy that worked on that for 3 hours and have him work on that part again. he's on vacation this week so we sadly have to wait. Once thats fixed, we will give you all an update on the engine. -Gerke Title: Re: Engine makes noise after overhaul Post by: rossocorsa on August 20, 2024, 03:16:19 PM To me it sounds like something simply not set up right have you tried moving the distributor whilst it is running to see if it gets smoother?
Title: Re: Engine makes noise after overhaul Post by: WestonE on August 20, 2024, 05:26:58 PM I agree that valve clearances are likely not correctly set and frankly if your mechanic can not do that job I would worry about the rest of the work. Set stone cold spark plugs out by using the tappet depression tool one at a time after using a syringe to remove the excess oil. You obviously measure first with feeler gauges looking for 0.40mm inlet and 0.45mm exhaust clearances. The Haynes Beta Manual tells you how, but you need a decent stock of shims to replace those note the right size. Avoid shims smaller than 3.50mm to prevent cam damage. If you have saved shims from previous engines you probably have lots of 4.20mm! Note always measure the shim thickness with a decent digital vernier or micrometer. to check the actual size and never use shims with heat bluing or surface scuffing.
Good luck. Eric Title: Re: Engine makes noise after overhaul Post by: peteracs on August 20, 2024, 10:37:36 PM Hello, Thanks for the replies. We have removed the cam covers and the oil is very much present at the top of the engine. As for the valve clearences, we will have to talk to the guy that worked on that for 3 hours and have him work on that part again. he's on vacation this week so we sadly have to wait. Once thats fixed, we will give you all an update on the engine. -Gerke Hi Gerke I suggest follow Eric’s comments, get yourself some feeler gauges and thereby have another pair of eyes check what is going on with the valves. It is very easy to check now you have the cam box covers off. If they are out then not a trivial job to sort, but at least you know and hence to ask the question why? Again as Eric suggests, I would then be questioning why he has not done the job correctly and hence what else is incorrect? Peter Title: Re: Engine makes noise after overhaul Post by: Gerke123 on August 21, 2024, 08:55:07 AM To me it sounds like something simply not set up right have you tried moving the distributor whilst it is running to see if it gets smoother? Yes, I tried this but there was no immediate change Title: Re: Engine makes noise after overhaul Post by: Gerke123 on August 21, 2024, 09:01:41 AM I agree that valve clearances are likely not correctly set and frankly if your mechanic can not do that job I would worry about the rest of the work. Set stone cold spark plugs out by using the tappet depression tool one at a time after using a syringe to remove the excess oil. You obviously measure first with feeler gauges looking for 0.40mm inlet and 0.45mm exhaust clearances. The Haynes Beta Manual tells you how, but you need a decent stock of shims to replace those note the right size. Avoid shims smaller than 3.50mm to prevent cam damage. If you have saved shims from previous engines you probably have lots of 4.20mm! Note always measure the shim thickness with a decent digital vernier or micrometer. to check the actual size and never use shims with heat bluing or surface scuffing. Good luck. Eric I took some measurements on the exhaust side. the first cylinder is at 0.50, 2, 3 and 4 have difficulty reaching 0.30........ I will see if I can obtain the special tool somewhere in the Netherlands. It's a shame about the three hours of work the technician put into this. -Gerke Title: Re: Engine makes noise after overhaul Post by: peteracs on August 21, 2024, 08:58:51 PM Hi
It is not a shame, I would tell him where to get off and not bother using him, never mind asking for my money back……. Hopefully it has not caused any long term damage. Time to check the inlet side. You should be able to find the tool easily, here is one advertised for Fiat 124 in Germany (same twin cam engine) but should be widely available at around 50 Euros. https://shop.wum-autoteile.de/Valve-adjustment-tool-Fiat-124 Peter Title: Re: Engine makes noise after overhaul Post by: Gerke123 on August 23, 2024, 08:53:42 AM Hi It is not a shame, I would tell him where to get off and no bother using him, never mind asking for my money back……. Hopefully it has not caused any long term damage. Time to check the inlet side. You should be able to find the tool easily, here is one advertised for Fiat 124 in Germany (same twin cam engine) but should be widely available at around 50 Euros. https://shop.wum-autoteile.de/Valve-adjustment-tool-Fiat-124 Peter Hi, The man from the garage comes to check the valve clearance in around 1-2 weeks time. He wants a chance to correct his mistake and I think I should give him that chance. Thank you so far and I will keep you informed. -Gerke Title: Re: Engine makes noise after overhaul Post by: Gerke123 on August 26, 2024, 07:12:22 PM Hi,
Today I spoke with the man who overhauled the rotating part of the engine, so not the guy who did the valves. He advised to check the oil for aluminum particles in the bearings. The oil was clean and clear so this is not the case. He said that if the valves are too tight you should not hear a ticking sound, only if they are too wide......anyone have experience with this? Gerke- Title: Re: Engine makes noise after overhaul Post by: peteracs on August 26, 2024, 10:49:50 PM Hi
In theory, yes, too wide gap will result in a noise, which is the cam hitting the shim on the steep part of the cam, ie instead of ‘gently’ reducing the gap. However if too small a gap maybe it is falling foul of something else? Also you only posted the exhaust side, not the inlet side values? I recently visited a fellow Spider owner who has a long knowledge of these engines and he had a chat many years ago with a Lancia factory mechanic whose comment was that the engines work best if you can hear the tappets, ie gap them on the loose side of the spec. This is purely anecdotal, so make of it what you will….. Peter Title: Re: Engine makes noise after overhaul Post by: Gerke123 on August 27, 2024, 06:07:43 PM Hi,
I took some more time and now come to the following measurements. E1 0.20 E2 0.15 E3 0.20 E4 0.20 now the inlet. I1 0.15 I2 0.25 I3 0.20 I4 0.25 What it should be E 0.45 - 0.51 and the inlet 0.39 - 0.45 there is a difference...... Title: Re: Engine makes noise after overhaul Post by: peteracs on August 27, 2024, 07:36:12 PM Hi
Yes, not good. Hope you can get it sorted out correctly. Peter Title: Re: Engine makes noise after overhaul Post by: HFStuart on August 29, 2024, 12:48:07 PM It seems unlikley that the clearances being 0.2mm too small would produce so much noise but I hope it turns out to be something simple.
Title: Re: Engine makes noise after overhaul Post by: Gerke123 on September 10, 2024, 05:09:10 PM Hi,
The mechanic at the garage has now adjusted the valves correctly and unfortunately the noise is still there. I'm going to take the engine, subframe and all, out again. I don't know anything else either. According to the mechanic, the noise is louder at the bottom of the engine than at the top. Gerke- Title: Re: Engine makes noise after overhaul Post by: WestonE on September 10, 2024, 05:35:27 PM Hi Gerke,
When you have the sump off check if number 2 conrod is hitting the fuel pump lobe on the Auxillary shaft. The Aux Shaft has to be precisely positioned at TDC or it will hit eventually breaking the conrod and punching a hole in the block. If you no longer use a manual fuel pump it is common to cut off the fuel pump drive lobe and insert a plug into the oilway after careful cleaning. With this done there is no need for precise timing of the Aux Shaft. How to do this is explained in Guy Crofts workshop manuals. Of course if your mechanic sets the shaft in the right place it does not hit the con rod. Otherwise look for a loose oil pump or oil drain pipe hitting the crank. After that it becomes poor assembly or incorrect bearing sizes. Unfortunately I have now seen these things too often from engine builders who should find other work! Eric PS with a bore scope you can inspect each cylinder through the spark plug hole looking for strike marks on the pistons from the valves. If standard pistons have been re-used which is rarely a good idea then the wrong size class in the wrong bore will create piston slap which is noisy. OE Size classes are stamped on the crank case sump join for each bore at the factory and detailed in GCs books. Title: Re: Engine makes noise after overhaul Post by: peteracs on September 10, 2024, 08:22:02 PM Hi Eric
Good call on the aux shaft, that may very well explain it. Peter Title: Re: Engine makes noise after overhaul Post by: rossocorsa on September 11, 2024, 10:29:21 AM Hi Eric Good call on the aux shaft, that may very well explain it. Peter Easy to check visually if the pulley is in the right position without taking anything apart Title: Re: Engine makes noise after overhaul Post by: Gerke123 on September 11, 2024, 05:08:54 PM Hi Eric,
This is a photo of the setting before installation. Visually it seems to be going well. I did use a different axle than the one that came out, but visually there was no difference. Title: Re: Engine makes noise after overhaul Post by: stableblock on September 11, 2024, 05:24:06 PM Its hard to see from the pic but looks like you could be a tooth out on the aux shaft. Certainly worth a closer look, dont adjust and run the engine unless you are sure. It should turn over by hand cleanly with the correct timing of the aux shaft but it might be hard to detect if there is only marginal contact.
Title: Re: Engine makes noise after overhaul Post by: squiglyzigly on September 11, 2024, 08:03:41 PM The belt is not fitted correctly.
The teeth are not located on the left side of the aux pulley. If this was run like this then is quite likely the timing moved. The belt would be also be under tensioned as soon as the teeth slip into place and unlikely to stay correctly timed. I hope this was adjusted before installation. Ian Title: Re: Engine makes noise after overhaul Post by: HFStuart on September 11, 2024, 08:27:01 PM Hi Eric Good call on the aux shaft, that may very well explain it. Peter It's also what I suggested two weeks ago :) Title: Re: Engine makes noise after overhaul Post by: WestonE on September 11, 2024, 08:30:48 PM What Ian (Squiggly Wiggly) Said I agree with.
Eric Title: Re: Engine makes noise after overhaul Post by: stableblock on September 12, 2024, 08:51:06 AM Good spot from the pic. Might need a new tensioner spring too.
Title: Re: Engine makes noise after overhaul Post by: Gerke123 on September 12, 2024, 03:13:33 PM hi to all,
This photo is taken before i turned the engine by hand, and all teeth were neatly in place after turning. I'm going to dismantle the engine in the coming weeks and will check the aux shaft first. I'll keep you informed. Gerke- |
