Title: door key number Post by: tonylanciabeta on November 04, 2008, 10:40:26 PM Hi I have just bought a coupe that is for restoration.
It has the ignition key but not the door/glovebox/fuel flap key. Does any one know if there is a way of telling the key reference from the locks or anywhere else? thanks spydervx ------------------------------------------------------- On the latching cam of the glove box door you will find a 4 digit number. This is the door key cut code. Hopefully it is the original cam. Being plastic are prone to breakage. ------------------------------------------------------ Hi stablemaster1 Thanks for the info. Yes I have checked and the only lock missing is the glovebox! I dont know if the code appears on any other locks will check them and see. Thanks for your help spydervx -------------------------------------------------------- |
