Title: Sump Plug Tool Post by: tonylanciabeta on November 04, 2008, 10:36:47 PM Hi Folks
I need to remove the sump plug from my 2000ie Coupe. I thought it was supposed to be a 12mm Hex fitting but it doesn't seem to be. And I can in at it to have a look. Does this need a speccial torx tool or something ? Thanks in Advance. Paul N Dublin ------------------------------------------------------------------------------------- Hi. I think it is a 12mm Allen key that you need. If that doesn't work, then you may not have a standard sump plug, or the sump plug may have become damaged due to overtightening in the past ? You really need to get the vehicle on a ramp so that you can safely view it. If the sump plug is b***ered, you might need to take the car to a garage who will weld on a connection that can be used to loosen the plug. They are used to doing this sort of thing.... Good luck. John |
