Title: Adding in new relays Post by: JohnFol on April 22, 2021, 01:22:56 PM After a bit of advice . .
I have added an electric fuel pump with associated relay. Also taken advice and added in a relay for the electric fan. About to add in a relay between ignition key and start motor to hopefully solve a voltage drop issue. I hear there may be other circuits that really should be triggered by relays, e.g. headlights? (any other suggestions welcome) There must be a better solution than to have odd relays around the engine bay? I'm also about to change the battery +ve -> Starter -> Alternator cabling and looking for a distribution block so the trickle charger, fan are not all connected to the battery terminal. So I'm thinking there must be a better solution. Has anyone fitted a distribution box / multi-relay box or similar? Title: Re: Adding in new relays Post by: WestonE on April 22, 2021, 05:31:30 PM Hi John
A relay on the top speed wiper feed so you actually get a top speed not 2 the same. A grey wire from memory. Pole Volt sell a nice 6 way distribution block I use for 12v+ battery and 12V switched distribution. They also supply modular relay and fuse assemblies that clip together. You should see pictures on my car build thread. On a Monte we use 2 change over relays per motor/side to get decent window speed. Take note Change over relays switch twin +ve to twin -ve. They are not wired like conventional realys. Eric Title: Re: Adding in new relays Post by: JohnFol on April 23, 2021, 12:48:53 PM Thanks Eric,
Now looked at loads of images, sites and perhaps what I am looking for does not exist. Imagine combining a Busbar with a relay block so you have a common rail for all the +ve feeds on Pin 30, rather than have individual wires. Seems there are combined Busbar fuse blocks but not relay. Don't beat me up too much on the sketch, but this is what I think would be an elegant solution. i.e. the socket for each relay is already connected to a 12v rail without the need to run a wire outside the box to a busbar / eyelet on the battery . . Does such a think exist, or am I missing something? Title: Re: Adding in new relays Post by: peteracs on April 23, 2021, 05:31:20 PM Hi John
I suspect the reason is that you have no flexibility to supply the relays with a separately fused supply which I think would be most likely preferable. Peter Title: Re: Adding in new relays Post by: JohnFol on April 23, 2021, 05:56:11 PM Makes sense.
Just going through the frustration of pre-made battery cables have 8mm rings, whereas the busbars have 6mm. Confident with wiring and standard crimps but not as confident with battery cable gague crimping . .. Title: Re: Adding in new relays Post by: frankxhv773t on April 23, 2021, 07:28:27 PM I'm just in the process of making a good set of Spyder lights out of two grotty sets one of which had relays for the main beam. They were bolted to the light unit mounting points with the standard main beam contact redirected to the relay.
Title: Re: Adding in new relays Post by: WestonE on April 24, 2021, 09:07:19 AM I found and bought a battery top distribution and relay box as you see on many modern cars. BUT it will not clear the bonnet on a Beta. It will work on a Montecarlo of course.
I have a hatred of 8 or 10 wires hanging off the battery +VE so I know why you are looking for a better way. By looping the fused feed into a bank of 4 relays and looping switched live paying attention to load it gets neater. I am adding a lot to my car so I have designed and built relay packs using advanced CAD (A4 Paper and a pencil). Start from what will fail or work better with a relay in a Beta and build to suit. Radiator Fans if upgraded or more added NB I have added feeds to lights so I know they are on Starter motor & Ignition feed - The ignition switches burn out frequently Wiper Motor top Speed - The switch gear resistance is high stopping top speed Brake Light Switch - They burn out (terrible on a Monte so every owner carries a spare if they have no relay) Electric Fuel Pump - because manual ones of decent spec are hard to find and the spec is at its limit Optional Electric Windows 4 x change over relays - the switches carry a heavy load so old ones can struggle I have 2 sets of new Renault pattern switches that fit straight in Main Beam Headlights - varies by generation of Loom so check NB on a Monte critical to avoid instant darkness Dip Beam Headlights - varies by generation of loom so check NB on a Monte critical to avoid instant darkness I have ECU Wideband Sensor Drive by Wire Throttle Alarm Tracker Accusump Cruise Control So I have to be tidy and put up with a lot of crimping. At least you get decent size wiring diagrams for Betas. Monte ones are terrible. Eric Title: Re: Adding in new relays Post by: HFStuart on April 24, 2021, 03:49:46 PM Thanks Eric, Now looked at loads of images, sites and perhaps what I am looking for does not exist. Imagine combining a Busbar with a relay block so you have a common rail for all the +ve feeds on Pin 30, rather than have individual wires. Seems there are combined Busbar fuse blocks but not relay. Don't beat me up too much on the sketch, but this is what I think would be an elegant solution. i.e. the socket for each relay is already connected to a 12v rail without the need to run a wire outside the box to a busbar / eyelet on the battery . . Does such a think exist, or am I missing something? Fused relays fed from via a common supply with a (high capacity) in-line fuse is probably as close as you could get but not as elegant as what you're thinking of. I had a look through the vehicle wring product catalogue and what you're after doesn't appear to be for sale. |
