Title: Windscreen trim question Post by: peteracs on April 19, 2021, 12:19:45 AM Hi
Something which has got me wondering. What is the typical width of the trim strip which runs around the windscreen to retain the roof lining and A pillar trim? I do not have the original and although what I ha e used appears to make sense with fitting of a bonded windscreen, I do wonder if I have used one which is too wide. Peter Title: Re: Windscreen trim question Post by: peteracs on April 28, 2021, 04:24:04 PM Could someone please let have a measurement on this one? I want to feel confident when I get my new screen that all will be ok....
Peter Title: Re: Windscreen trim question Post by: Nigel on April 28, 2021, 10:11:18 PM Hi Peter,
I can't measure as my screen is in, but judging by the photo in your wiper thread [good work btw] that trim you've used will be fine. It may even be narrower than OE. Pics for reference if they help. Title: Re: Windscreen trim question Post by: peteracs on April 28, 2021, 10:48:28 PM Hi Nigel
You look like you have the removable rubber seal on your screen? It looks to be completely different to the bonded method, so any measurements would not be useful sadly. Thanks for trying! Peter Title: Re: Windscreen trim question Post by: smithymc on April 29, 2021, 09:16:52 AM Peter
Is my screen any more suitable? Pics attached. Mark Title: Re: Windscreen trim question Post by: peteracs on April 29, 2021, 09:30:44 AM Hi Mark
Perfect, many thanks Peter Title: Re: Windscreen trim question Post by: peteracs on April 29, 2021, 10:21:26 AM Just measured mine and it is approx 13mm, so not too far away from Mark’s which will be original. So going to leave as is, I think there is enough space to allow the bonding material to attach and seal around the metal to give a good waterproof seal.
Peter Title: Re: Windscreen trim question Post by: smithymc on April 29, 2021, 01:35:48 PM No problem Peter I should have stated it’s 10mm overall as close as you can measure in case the photo wasn’t legible .
Mark |
