Title: Removing strut inserts Post by: tonylanciabeta on November 01, 2008, 07:53:47 PM Does anyone know which tool I need to remove the nut in top of the strut that hold in the insert?
And where I can get one. Mark -------------------------------------------------- 1 Clamp the strut 2 spray internal nut with WD40 (to aid loosening) 3 use cold chisel and hammer on the lugs of the nut to loosen (It destroys the nut) It will eventualluy come loose. 4 the new strut insert should have a replacement nut (Macpherson does) ------------------------------------------------------ HI Mark, You need 88031008 as per thge factory tools manual. I had one made for about GBP20. ------------------------------------------------------- |
