Title: LHD to RHD conversion? Post by: megaera on October 14, 2020, 12:50:44 PM So...... as in the title, really.
Has anyone carried out a left to right hand drive conversion? If so - could you tell me how straightforward it is? Apart from the obvious bits (dash, steering rack, servo, pedal box, wiper arms, some wiring) are there any other bits required? This would be on a late 2000ie, with a compatible donor vehicle and is very much a hypothetical idea, at the monent. Thank Title: Re: LHD to RHD conversion? Post by: WestonE on October 14, 2020, 04:32:11 PM With a good complete donor vehicle this is definitely possible. Expect to strip the engine bays and cabins of both cars and to be swapping the firewall over between the shells along with the steering column support structure. This is cutting and welding so great care will be needed to protect external paint and any glass left in the shell. I assume your idea is to find a LHD car from somewhere hot and dry so without our typical rust and make it RHD.
I think I would want to be sure it can be registered in the UK without a Q Plate before going too far. Good Luck Eric Title: Re: LHD to RHD conversion? Post by: megaera on October 14, 2020, 04:44:40 PM Thanks for your reply.
Actually, I already have a superb one-previous-owner LHD 2000ie - with a mere 45,000 miles. I was quite happy to leave things as they are - but the chance of a RHD donor vehicle gave me the chance to consider a conversion. To be honest, I was rather hoping the firewall would be manufactured as either/or LHD/RHD - to save on tooling at the factory. So, the requisite number of openings would be available for both options....? If, as you suggest, this would need cutting and swopping over between the two vehicles - I think I may just keep it as a “leftie”. The car is in really excellent condition and I wouldn’t want to potentially mess things up..... if, however, it was just a case of changing over various components etc....well, that I would definitely be happy to do. Maybe I can check on the microfiche for firewall differences? Thanks again Title: Re: LHD to RHD conversion? Post by: megaera on October 14, 2020, 06:42:43 PM Oh, well....that’s the end of that idea ;)
01 - sx 02 - dx |
