Technical stuff => Engine => Topic started by: BetaSteve on November 04, 2019, 05:19:55 AM
Title: Oil Pressure Warning Light
Post by: BetaSteve on November 04, 2019, 05:19:55 AM
Hi All
I have a problem with my '78 Beta coupe that's been getting progressively worse over the last few years.
If it hasn't been started for 1-2 weeks, it takes a lot of cranking - sometimes well over a minute - for the oil pressure warning light to go out, at which point the electric fuel pump will kick in and start to pump fuel through, and away it goes.
Have others seen this problem ?
Any thoughts/suggestions as to how best to diagnose/fix this ?
Is it likely to be the oil pump itself, or a dodgy oil pressure sender ?
Steve
Title: Re: Oil Pressure Warning Light
Post by: HFStuart on November 04, 2019, 08:25:36 AM
You can allways check the pressure by temporarily fitting a capillary gauge (almost always reliable).
I wonder if you have an oil filter without non-return springs? It could be draining right down and it would take a while to fill at cranking speeds.
Post by: rossocorsa on November 04, 2019, 09:06:49 AM
I think at cranking speed it will take a while for the light to extinguish, the engine is not turning over all that fast I think in most cases the light only goes out when it fires. As already stated above you could put a gauge on it to see if pressure is generally low or not. Instant starting may seem desirable but having to turn over a bit first is definitely an advantage  in terms of getting oil flowing
Post by: BetaSteve on November 07, 2019, 10:07:24 PM
Thanks for the suggestions, will check that and replace the filter just in case.
BTW, when I say it takes a lot of cranking, I mean a lot (!) - it has been enough to flatten the battery on occasions.
Am I right in thinking that others have the same cutout switch, preventing the fuel pump from running until the oil pressure light goes out ?
I guess the other option is to start (& drive) it more often (!)
Post by: rossocorsa on November 07, 2019, 11:49:45 PM
Not as far as I am aware, I am guessing you are in USA as European cars of this vintage have manual type pumps?
Post by: peteracs on November 08, 2019, 12:39:20 AM
From what you have written, it sounds like the engine used to get up to oil pressure much quicker before. I would check the oil pump, filter/relief valve. You could always wire in a switch to allow the pump to run initially and turn this off after starting, but obviously you run the risk of forgetting and hence not having the comfort of the pump stopping in the event of an accident etc.
Post by: BetaSteve on November 10, 2019, 10:10:25 AM
Actually from Aust, the car definitely doesn't have all the US specific mods.
Anyway, thanks all for the comments & suggestions, will check the filter & pump, and if they look normal, try a separate switch for the pump.
Steve
Post by: squiglyzigly on November 10, 2019, 12:36:15 PM
The oil pressure switch may be faulty, they can fail. Might be worth replacing it for a couple of dollars to eliminate it from the equation.
