Title: Beta Saloon heater matrix Post by: squiglyzigly on January 25, 2019, 06:19:28 PM Does anyone know if the S2/S3 coupe/hpe heater matrix is the same as Saloon S2 matrix?
Thanks Ian Title: Re: Beta Saloon heater matrix Post by: rossocorsa on January 27, 2019, 09:58:09 PM Does anyone know if the S2/S3 coupe/hpe heater matrix is the same as Saloon S2 matrix? Thanks Ian I can have a look but can I clarify what you mean by S2/3 are you really meaning S2 FL (S3 in Italy) and S2 FL 2 (S4 in Italy) my microfiche reader isn't working so can't check the really late cars but I'll have a look. Title: Re: Beta Saloon heater matrix Post by: rossocorsa on January 28, 2019, 12:21:09 AM S2FL (Series 3) coupé/hpe/spider vs. Series 2 update (long gutter, electronic ignition) berlina matrix is the same. Earlier S2 cars it appears that all except some 1300 berlina are the same. Even most S1 seem to have the same matrix although they offer a different one for scandanavian countries ( probably when Saab were selling them!)
Title: Re: Beta Saloon heater matrix Post by: squiglyzigly on January 28, 2019, 05:20:53 PM Thanks for that. The Saloon that I’m restoring is a ‘78 build/‘79 uk registered short gutter model (with electronic ignition) and I’m not sure what condition the matrix will be in when it’s running as the stripped engine had head gasket problems.
I have a couple of heater boxes from 81-84 coupe/hpe in the loft, and so I was hoping they will fit should I need one. Thanks again Ian Title: Re: Beta Saloon heater matrix Post by: rossocorsa on January 28, 2019, 09:43:27 PM Thanks for that. The Saloon that I’m restoring is a ‘78 build/‘79 uk registered short gutter model (with electronic ignition) and I’m not sure what condition the matrix will be in when it’s running as the stripped engine had head gasket problems. I have a couple of heater boxes from 81-84 coupe/hpe in the loft, and so I was hoping they will fit should I need one. Thanks again Ian I'll try to remember to check the late series ones too but suspect they will be the same as well so all good news! Unusual for lancia really! |
