Technical stuff => Brakes => Topic started by: aldad138 on November 17, 2015, 12:34:59 AM
Title: Rear Brake Rotors
Post by: aldad138 on November 17, 2015, 12:34:59 AM
Anyone have a source for rear rotors, for my 1979 Coupe?  Front ones, easy to find.
I am in the USA and any help is appreciated.
Thanks!
Title: Re: Rear Brake Rotors
Post by: Neil-yaj396 on November 17, 2015, 07:35:14 AM
Betaboyz Parts (UK - link at top of this page) have them.
Post by: peteracs on November 17, 2015, 11:24:00 AM
Neil, page says no availability at present.
This guy appears to have the correct EBC part DO68, but guess they need to be asked for sure
http://www.ebay.co.uk/itm/REAR-EBC-BRAKE-DISCS-LANCIA-BETA-2-0-SUPERCHARGED-82-84-/181154288617?fits=Car+Make%3ALancia%7CModel%3ABeta%7CCars+Year%3A1977%7CPlat_Gen%3A828BC%7CCars+Type%3A2000&hash=item2a2da313e9:g:0NYAAOxykVNRsdmY (http://www.ebay.co.uk/itm/REAR-EBC-BRAKE-DISCS-LANCIA-BETA-2-0-SUPERCHARGED-82-84-/181154288617?fits=Car+Make%3ALancia%7CModel%3ABeta%7CCars+Year%3A1977%7CPlat_Gen%3A828BC%7CCars+Type%3A2000&hash=item2a2da313e9:g:0NYAAOxykVNRsdmY)
Post by: Neil-yaj396 on November 18, 2015, 07:33:13 AM
Funny, they were showing as in stock when I first looked.
Post by: frankxhv773t on November 25, 2015, 10:03:38 PM
Forgive my ignorance but what is the difference between front and back? I have some new rotors in the garage and just assumed they were the same both ends so I ought to find out what I have actually got.
Post by: peteracs on November 25, 2015, 11:09:54 PM
From memory the rears are thinner than the fronts, but do look very similar.
Post by: lukasdeopalenica on November 26, 2015, 08:19:59 AM
They look similar but have different thickness and offset.
Post by: smithymc on November 26, 2015, 08:45:34 AM
I have a set of new EBC rears if you want some dimensions to help in sorting through what you have?
Post by: frankxhv773t on November 27, 2015, 10:48:32 AM
I had thought of just seeing if there were any differences in the ones I have but knowing my luck they would be two different specs of front disc. Some dimensions for rear ones would be handy if you don't mind.
Post by: smithymc on November 27, 2015, 11:21:52 AM
I will measure up over the weekend if that's ok.
Post by: lukasdeopalenica on November 27, 2015, 11:29:56 AM
Both rears and fronts have 251mm in diameter. Rears have ca. 9mm thickness, whereas fronts have ca. 11mm.
Do not mislead with montecarlo rotors, they are also 251mm, but does not fit. They differ e.g. in lack of a rim centering flange.
