Title: Charging warning light Post by: lukasdeopalenica on May 05, 2015, 10:25:23 PM Recently when I was finishing a short trip the warning light came up. Measuring of the voltage shown 12V. I decided to replace the voltage regulator. Now the voltage is OK, between 13,5-14,4V, but the light is still on. When I increase revvs it dims a bit, however. The voltmeter at the dashboard also shows proper values.
What can be the cause of such situation? Title: Re: Charging warning light Post by: lbcoupe76 on May 06, 2015, 12:57:39 AM Bad earth maybe?
Title: Re: Charging warning light Post by: rossocorsa on May 06, 2015, 07:59:31 AM They are prone to that it could be earthing of the instrument panel at fault but tbh I wouldn't worry too much about it
Title: Re: Charging warning light Post by: lukasdeopalenica on May 06, 2015, 02:19:05 PM Thanks. I will check it thoroughly. What about diodes? What are the symptoms if they are failed?
Title: Re: Charging warning light Post by: lukasdeopalenica on May 19, 2015, 07:16:30 AM The alternator brushes needed probably some time to be grinded. After few kilometers the light operates as it is supposed to.
