Title: Exhaust manifold for s2 pre-facelift spider Post by: droptop on April 21, 2015, 04:49:43 AM The gasket between the manifold and downpipe failed at the weekend on my 1978 s2 pre-facelift spider 2 liter, and when I took a look, the studs/nuts look like they're never going to seperate and one stud appears to be sheared off so I figure I'll need to replace the manifold.
I have one but I'm not sure of its origin. It came off what turned out to be a Montecarlo head which had VX cam boxes and cams fitted so I've no idea what it was actually fitted to! The part number cast on it is 82300503 I also have a 1979 (despite being first regd. in '82) 2.0 coupe so maybe that manifold would suit? Thanks in advance for helping cure the less than sweet sounding exhaust note Title: Re: Exhaust manifold for s2 pre-facelift spider Post by: peteracs on April 21, 2015, 04:35:20 PM Hi
The parts manual I have shows the exhaust manifold as 82300504 and is the same for 1600 and 2000 model engines on the pre f/l. Peter Title: Re: Exhaust manifold for s2 pre-facelift spider Post by: droptop on April 22, 2015, 08:05:27 AM Thanks Peter.
Looks like I need a manifold so, as my other ones are off facelift cars although I could probably use the corrosponding downpipe. I have to admit to enjoying the "hardship" of having a car that sometimes needs repair because my daily car is ultra reliable and my van is disposable (Renault) and not worth the cost of a replacement clutch ;D Title: Re: Exhaust manifold for s2 pre-facelift spider Post by: peteracs on April 22, 2015, 09:09:27 AM Hi
I would have thought the carb facelift exhaust manifolds would be the same if not the later ones as well? Peter Title: Re: Exhaust manifold for s2 pre-facelift spider Post by: droptop on April 22, 2015, 06:13:45 PM Hi I would have thought the carb facelift exhaust manifolds would be the same if not the later ones as well? Peter Of course. The gaskets certainly seem to be. Belay that panic matey Title: Re: Exhaust manifold for s2 pre-facelift spider Post by: mangocrazy on April 08, 2016, 06:44:33 PM As posted in Parts Wanted, what engine would exhaust manifold part number 82301243 be originally fitted to?
Title: Re: Exhaust manifold for s2 pre-facelift spider Post by: rossocorsa on April 09, 2016, 02:17:10 PM busy at moment but will try to look later
Title: Re: Exhaust manifold for s2 pre-facelift spider Post by: rossocorsa on April 10, 2016, 09:50:54 AM Can't find find that number I'm afraid
Title: Re: Exhaust manifold for s2 pre-facelift spider Post by: mangocrazy on April 10, 2016, 05:32:09 PM Hi rossocorsa, thanks for trying, anyway. Much appreciated.
Title: Re: Exhaust manifold for s2 pre-facelift spider Post by: Neil-yaj396 on April 11, 2016, 06:35:00 AM Any clues as to where that manifold came from?
Title: Re: Exhaust manifold for s2 pre-facelift spider Post by: mangocrazy on April 11, 2016, 07:19:36 PM From memory it came from an S2FL Coupe. There was some confusion over whether it had a 1600 or 2000 engine.
