Title: Additional gauge wiring Post by: lanciamad on December 28, 2014, 03:47:36 PM I've fitted some additional gauges for oil pressure and water temperature, 12v and earth aside, the signal wire for both, can it be spliced off the original wiring to give readings? Or will effectively splitting the wiring to two gauges (as I would like to keep the originals active) cause mayhem?
Title: Re: Additional gauge wiring Post by: rossocorsa on December 28, 2014, 04:47:21 PM I suspect this may not work but more importantly if you are looking for accurate readings you'd really need to use better sender units anyway
Title: Re: Additional gauge wiring Post by: lanciamad on December 28, 2014, 06:31:23 PM I would guess that is the case too, perhaps i'll have to fit another union to run two senders
Title: Re: Additional gauge wiring Post by: HFStuart on December 28, 2014, 10:01:55 PM If you can always go capillary for oil pressure - they're pretty much infallible.
Title: Re: Additional gauge wiring Post by: gengis on December 28, 2014, 11:15:55 PM This would cause a parallel current path via the two gauges to earth, and cause neither of them to read correctly. Both are standalone and matched...sender - instrument schemes.
See my post on "sump removal" there is some useful info there. |
