Title: Gearbox Oil Drain Plug Post by: Neil-yaj396 on October 27, 2014, 03:00:02 PM Does this require the same tool as the sump plug to remove it, or a smaller hex key? My sump plug tool wouldn't fit, but I didn't get right under the car, so I guess the plug could be full of crud?
Title: Re: Gearbox Oil Drain Plug Post by: HFStuart on October 27, 2014, 08:29:40 PM Same size - 12mm hex I think
Title: Re: Gearbox Oil Drain Plug Post by: Neil-yaj396 on October 28, 2014, 08:48:16 AM Thank Stuart,
I'll have to get under and give it a good clean out with a screwdriver I guess. Neil Title: Re: Gearbox Oil Drain Plug Post by: Neil-yaj396 on November 01, 2014, 02:27:43 PM It turned out to be a 10mm hex on mine. I only have a large Allen key in this size, but with a bit of a push I got the plug loose. The oil was very dark, so obviously it was worth changing it.
This flexible long neck funnel has been a Godsend for both oil changes, but particularly the gearbox. I had to remove the battery and it's tray to get proper access. The funnel was £1 from B&M, one of the best pounds I've spent on tools I think. Title: Re: Gearbox Oil Drain Plug Post by: cheeky monkey on November 02, 2014, 11:24:25 PM Quote This flexible long neck funnel has been a Godsend for both oil changes Good buy Neil !.. Which gear oil did you go for? G Title: Re: Gearbox Oil Drain Plug Post by: Neil-yaj396 on November 03, 2014, 08:14:06 AM Castrol Universal 75W-90.
