Title: Subframe Bolt Beta 2000 Post by: simplydelboy on July 16, 2014, 09:02:41 AM Hi All
I'm needing a subframe bolt to replace one on my 2000 Spyder. I'm pretty sure the part number is 11422321 if that helps. I've tracked it down to an Iveco part with the same number which may be the same thing??, not sure, but no website has them apart from possibly a place in Latvia! Can anyone help? BTW the recently acquired 2000 Coupe received it's MOT yesterday, just needed a little welding and attention to the brakes (as usual). More on this when I take it out, Regards Derek Moore Title: Re: Subframe Bolt Beta 2000 Post by: HFStuart on July 16, 2014, 10:21:33 AM Front or rear?
I think I have both in my shed. Title: Re: Subframe Bolt Beta 2000 Post by: lbcoupe76 on July 16, 2014, 10:54:59 PM Can you take the bolt to a bolt specialist to match?
Title: Re: Subframe Bolt Beta 2000 Post by: simplydelboy on July 18, 2014, 06:40:34 PM Hi Stuart, and bagospuds.
Many thanks for getting back to me. Yes I would go to a bolt specialist if necessary, but Stuart, if you are willing to let it go for a consideration, I'm looking for the front driver side, sorry I didn't make it clear, Regards Del Title: Re: Subframe Bolt Beta 2000 Post by: HFStuart on July 21, 2014, 07:26:40 PM You have a pm
