Title: Windscreen - when did they stop doing bonded? Post by: HFStuart on June 11, 2014, 12:55:21 PM Does anyone know when they switched the screen on the Spider from bonded type to rubber sealed and how I might tell the difference on a bare screen?
Title: Re: Windscreen - when did they stop doing bonded? Post by: peteracs on June 11, 2014, 01:28:49 PM Hi Stuart
Did not realise there were any UK unbonded versions on Spider, I thought it came in after they had finished? The difference will be in the p/n, but I had both next to each other and there is just a centimetre or so difference in the size, so I would measure them to make sure. Peter Title: Re: Windscreen - when did they stop doing bonded? Post by: lukasdeopalenica on June 11, 2014, 03:58:54 PM They definitely differ in height. As far as I know the bonded windscreen, at least in coupes and HPEs is ca 1cm higher than the rubber seal mounted (68,5cm)
Title: Re: Windscreen - when did they stop doing bonded? Post by: Neil-yaj396 on June 11, 2014, 07:21:11 PM Hi Stuart Did not realise there were any UK unbounded versions on Spider, I thought it cam in after they had finished? The difference will be in the p/n, but I had both next to each other and there is just a centimetre or so difference in the size, so I would measure them to make sure. Peter Also thought only the VX and ie models had the unbonded screen in the UK. Title: Re: Windscreen - when did they stop doing bonded? Post by: rossocorsa on June 11, 2014, 08:51:39 PM Will try to check the microfiche when I have time, not convinced that lancia would have fitted the rubber seal type to spiders as the bonded screen will assist rigidity never actually tried it but I was under the impression that the screens are interchangeable in that you could fit a screen with rubber to a bonded screen car(??) anyone know for certain?
Title: Re: Windscreen - when did they stop doing bonded? Post by: peteracs on June 11, 2014, 09:58:27 PM Will try to check the microfiche when I have time, not convinced that lancia would have fitted the rubber seal type to spiders as the bonded screen will assist rigidity never actually tried it but I was under the impression that the screens are interchangeable in that you could fit a screen with rubber to a bonded screen car(??) anyone know for certain? I can confirm they are different sizes and hence would not be able to fit the later one to a bonded screen. Peter Title: Re: Windscreen - when did they stop doing bonded? Post by: rossocorsa on June 11, 2014, 10:54:02 PM I thought the aperture was the same and the sealing method dictated the difference in screen size as the rubber seal is thicker ??
Title: Re: Windscreen - when did they stop doing bonded? Post by: lukasdeopalenica on June 12, 2014, 07:37:25 AM That is the point.
Title: Re: Windscreen - when did they stop doing bonded? Post by: rossocorsa on June 12, 2014, 08:04:50 AM check this old thread http://www.betaboyz.myzen.co.uk/forum/index.php?topic=2100.0 (http://www.betaboyz.myzen.co.uk/forum/index.php?topic=2100.0) for information that I found then on microfiche
Title: Re: Windscreen - when did they stop doing bonded? Post by: HFStuart on June 12, 2014, 08:52:11 AM Much appreciated
Title: Re: Windscreen - when did they stop doing bonded? Post by: peteracs on June 12, 2014, 10:08:11 AM check this old thread http://www.betaboyz.myzen.co.uk/forum/index.php?topic=2100.0 (http://www.betaboyz.myzen.co.uk/forum/index.php?topic=2100.0) for information that I found then on microfiche Following on from your comment in this thread what is the size of the fiches? Peter Title: Re: Windscreen - when did they stop doing bonded? Post by: rossocorsa on June 27, 2014, 08:08:28 AM 240mm x 180mm
apologies for slow reply been rather busy! I can check this again but last time I enquired only the normal smaller format fiche could be done Title: Re: Windscreen - when did they stop doing bonded? Post by: spud on June 27, 2014, 01:02:45 PM Also thought only the VX and ie models had the unbonded screen in the UK. My VX has a bonded screen from new. Andrew. |
