Technical stuff => Engine => Topic started by: mtulloch on July 02, 2013, 10:16:40 PM
Title: VX Engine
Post by: mtulloch on July 02, 2013, 10:16:40 PM
Does anyone have a cutaway drawing which shows the coolant galleries in the VX engine? It looks like there is no coolant flow through the auto choke. The pipes are clear so it looks like there may be a blockage in the inlet manifold area itself.
Title: Re: VX Engine
Post by: rossocorsa on July 04, 2013, 08:14:00 AM
I probably do have one and I will try to look when I have some time, bit overloaded with work and stuff at the moment!
Post by: mtulloch on July 05, 2013, 10:59:49 AM
Thanks. I've re routed the pipes so that at least the coolant flows through the auto choke unit. At least if the car's used, the blockage may open up with the heat of the engine.
Post by: rossocorsa on July 07, 2013, 09:51:50 AM
(http://i724.photobucket.com/albums/ww247/rossocorsa/DSCF4481.jpg)
just looking for one of the actual engine will post if I find one
Post by: rossocorsa on July 07, 2013, 10:41:47 AM
for standard engine, this is all I could find couldnt find one showing flow in block/head although I probably have one some where
(http://i724.photobucket.com/albums/ww247/rossocorsa/DSCF4483.jpg)
