Technical stuff => Engine => Topic started by: Air_Hair_Lair on March 15, 2013, 06:45:53 PM
Title: Carb for a Lancia Beta Coupe 1600 (1981)
Post by: Air_Hair_Lair on March 15, 2013, 06:45:53 PM
Hey All
I've got a problem with one of my carbs in that it is over flowing petrol from the top.  I know this could be related to the float simply being stuck, or something worse.
I've not had any experience in taking them apart am a little hestitant to just jump in.  I am awaiting some advice from a garage, but in the meantime I was wondering if anyone can give me either a little advice on either going about taking one apart and looking at the float and also any rough costs of refurbished/second hand carbs and where I can go about purchasing them. (currently there is one on ebay for about £20 with 2 days left on it).
Also if any of you have had a similar problem if you could let me know what you did to fix it, or where you went to fix it that would be top notch!
Thanks a lot in advance!
Title: Re: Carb for a Lancia Beta Coupe 1600 (1981)
Post by: Neil-yaj396 on March 15, 2013, 07:57:54 PM
Sounds like a stuck or punctured float. The carbs are fairly easy to strip down. I think the whole top half comes off to get at the float chamber, but not sure where you'd get a new float, though it's more likely to be stuck rather than holed.
Might be worth a punt on eBay, so long as it's the correct carb for your car. A refurbished carb will be £100+.
Post by: thecolonel on March 15, 2013, 08:24:10 PM
You should be able to get à new float from eurocarb.
Post by: Ammy on March 15, 2013, 08:29:35 PM
If you look on the Lancisti web page,  I have sent copies of the Weber technical sheets for the carbs you're most likely to  have.  They show exploded views,  which explain everything you need.
Ammy
Post by: Ammy on March 15, 2013, 08:34:54 PM
Explanation.! ! !   They are on the Forum under  34DATRA-34DATRA.
Post by: peteracs on March 16, 2013, 12:58:26 AM
Hi All
There is a guy on Ebay selling Datr refurb kit for £35ish, let me know if you need a link to it. It includes new floats.
Post by: Neil-yaj396 on March 16, 2013, 01:40:46 PM
Not as likely, but does your car have a fuel return pipe (smaller of two pipes attatched to the carb that include the main fuel inlet pipe)? If this is blocked and you are only idling the engine this could be either causing or exacerbating the flooding.
Post by: Air_Hair_Lair on March 18, 2013, 12:39:13 PM
Cheers for you help all, looking into it now.   :D
*EDIT
Ammy if you could post a link to the technical sheets that would be brilliant.  I've searched for them on the site and seem to only find wanted posts, or posts about other issues from other people :)
Post by: Ammy on March 18, 2013, 05:00:22 PM
Can't handle attachments on this site but they are on  Lancisti-- Home --Articles-- more articles --5 days ago
