Technical stuff => Brakes => Topic started by: smithymc on February 05, 2013, 01:16:34 PM
Title: Brake Pipes
Post by: smithymc on February 05, 2013, 01:16:34 PM
Another basic one I'm afraid - should I get copper or copper-nickel pipes?
Title: Re: Brake Pipes
Post by: lukasdeopalenica on February 05, 2013, 06:26:03 PM
I use copper pipes. They work fine and are easy to fit, but should be made of certified pipes, however.
Post by: MattNoVAT on February 05, 2013, 07:46:26 PM
I use copper-nickel myself.
Post by: HFStuart on February 05, 2013, 10:19:44 PM
Copper nickel here too. Pretty easy to work but might need more than a cheapo pipe flarer.
Post by: smithymc on February 06, 2013, 08:45:22 AM
Thanks all.
I also want to clarify sizes for new male fittings, as there seem a range available - are they 10mm x 1.25mm or 1mm?
From bitter experience last night, a proper spanner for the fittings seems a good investment too.
On the plus side, all 4 bleed nipples at the front are working fine.
Thanks again.
Post by: lukasdeopalenica on February 06, 2013, 04:42:45 PM
Originally should be 10X1.25. Open hex spanner is strongly advised.
Post by: spud on February 07, 2013, 09:40:05 PM
Now that's a rarity...
Pipes- I would go with copper/nickel or what it's often known as, kunifer. Copper goes brittle with age and often gets a 'furry' appearance. Kunifer tends to resist this strange effect and stays looking 'as new'. Kunifer is quite a lot stronger too whilst still easily shaped for bends etc.
Andrew.
