Title: Accelerator pedal movement Post by: smithymc on February 03, 2013, 03:07:48 PM This may be a daft one, but see photos- the pedal floats sideways.
Not urgent, as she is not on the road, but I noticed it yesterday while starting her up. Note cool carpet offcut mats too - again contemporary with the car. Any ideas? Mark Title: Re: Accelerator pedal movement Post by: HFStuart on February 03, 2013, 09:18:28 PM This happened to me.
The nylon block the pedal hinges in is securred to the bulkead by an M6 nut on a stud and a locating pin that stick out of the back of the block. Your pin has sheared off. About the only safe fix is a replacement block though you may get away with araldite or similar for a while. They do come up on eBay every so often. Or you could get one machined up in aluminium. Edit - Found a picture http://www.ebay.com/itm/lancia-beta-throttle-pedal-bracket-/250988985876?ViewItem=&item=250988985876&nma=true&si=2JzH5Y8k4hsUDwV4BhinNPjv3pg%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557 (http://www.ebay.com/itm/lancia-beta-throttle-pedal-bracket-/250988985876?ViewItem=&item=250988985876&nma=true&si=2JzH5Y8k4hsUDwV4BhinNPjv3pg%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557) That one was sold by Chris Bastow ex of Betacar in Bradford - it might me worth asking him if he's got another. Title: Re: Accelerator pedal movement Post by: archigraphe on February 03, 2013, 11:16:00 PM Be aware, this part is different between the first and later series...
Title: Re: Accelerator pedal movement Post by: smithymc on February 04, 2013, 03:02:28 PM Thats fantastic - thanks.
Looking up I can see the white plastic hinge sliding about so can get onto that- another one for the list! Mark |
