Title: Bits Required (again). Post by: Tony B on August 27, 2012, 11:19:10 AM Dear Gang,
I'm short of a couple of things namely the 'carpet' that fastens onto the inside of the bonnet (MIA when I bought her) - could also do with a couple of clips?? The other item is a Vegliaflash - mine only displays '0000' when both buttons are pressed - blank any other time. Any assistance please PM me. I also need to learn to spell sill / cill? (earlier post). Kind regards, Tony ::) Title: Re: Bits Required (again). Post by: MattNoVAT on August 27, 2012, 12:05:34 PM Tony,
If you mean the bonnet liner then these are available through lanciabetaspares.co.uk The clips that hold the liner in place are hard to find but I have used modified Subaru clips ( just cut a bit off ) I have about five Veglia clocks but everything is packed up in boxes so hard to get at. Hopefully someone else can assist, but of you get stuck pm me. Title: Re: Bits Required (again). Post by: Tony B on August 27, 2012, 06:26:49 PM Hi Matt,
I found a couple of additional clips in my box but alas the site says 'sold out' in terms of the liner. I'll keep looking and ditto the Veglia. Regards, Tony. Title: Re: Bits Required (again). Post by: droptop on August 27, 2012, 08:46:23 PM Would that Veglia item be a digital clock?
If so, I have one but without a facelift car to connect it to, I've no way of testing it. If you want to try it, I can send it to you and we can sort it out if it works. |
