Title: rear suspension bushes Post by: thecolonel on February 14, 2012, 06:31:59 PM Does anyone have the original part numbers
For all the rear suspension bushes please ? Links, anti-roll bar etc. Geoff Title: Re: rear suspension bushes Post by: MattNoVAT on February 14, 2012, 08:15:53 PM 82320406 is the p/n of the bush (silent block) - same for both ends of the transverse link arms.
Be careful with these as they should be 30mm diameter and later Lancias (Delta) used 32 mm - I know because I was given a set of 4 years ago and thought I'd use them only to find they are 2mm too big. But then if a Gamma uses slightly bigger 32mm bushes - I have a set of 4 :-) Title: Re: rear suspension bushes Post by: thecolonel on February 14, 2012, 10:26:31 PM That's the same number as the gamma bush.
The other one is the anti-roll bar bush In the base of the hub . Hopefully it's the same as the Beta. Title: Re: rear suspension bushes Post by: thecolonel on February 14, 2012, 10:54:02 PM The other bush number is 82315794
Geoff Title: Re: rear suspension bushes Post by: MattNoVAT on February 14, 2012, 11:01:17 PM That might explain it as the ARB to base of hub on a S1 is a different design to the later cars.
Thanks Geoff |
