Technical stuff => Engine => Topic started by: raz1966 on October 19, 2011, 05:51:29 PM
Title: cambelt
Post by: raz1966 on October 19, 2011, 05:51:29 PM
where can i get a cambelt for my 2000 beta? is it the same as 1600?
Title: Re: cambelt
Post by: HFStuart on October 19, 2011, 07:33:11 PM
No it's not. Most good motor factors will be able to get you one.
Title: Re: cambelt
Post by: raz1966 on October 20, 2011, 04:35:40 PM
 cheers mate
Title: Re: cambelt
Post by: Neil-yaj396 on October 21, 2011, 07:00:28 AM
Usually a few on eBay.
Title: Re: cambelt
Post by: MattNoVAT on October 21, 2011, 10:52:50 AM
Or ask Mark W to supply the whole kit.  Www.lanciabetaparts.co.uk
Title: Re: cambelt
Post by: HFStuart on December 18, 2011, 12:37:37 PM
Doing some trawling the internet today came up with some handy links for timing belts:
http://www.google.co.uk/url?sa=t&rct=j&q=mitsubishi+qtb123&source=web&cd=9&ved=0CG0QFjAI&url=http%3A%2F%2Fwww.adcoach.co.za%2Fcatalogues%2Fdoc_download%2F26-timing-belts-echlin&ei=IMztTvSyGMrOhAe24IWiCA&usg=AFQjCNE5vrGAfWBGf4tRjJsuOAa2keiH6Q (http://www.google.co.uk/url?sa=t&rct=j&q=mitsubishi+qtb123&source=web&cd=9&ved=0CG0QFjAI&url=http%3A%2F%2Fwww.adcoach.co.za%2Fcatalogues%2Fdoc_download%2F26-timing-belts-echlin&ei=IMztTvSyGMrOhAe24IWiCA&usg=AFQjCNE5vrGAfWBGf4tRjJsuOAa2keiH6Q)
http://www.autoraid.ru/catalog/files/DAYCO_Cross_All.xls (http://www.autoraid.ru/catalog/files/DAYCO_Cross_All.xls)
Interestingly theres no listing for a 1" wide belt with the same tooth profile and 148 teeth.
So if you're ever struggling to find a belt here are the cross references, all for standard 19mm wide belts
2.0 148 Tooth
A E AUTOPARTS   TB122
BANDO   148ZA19
BOSCH   9144161148
COLMANT CUVELIER   148R190
CONTINENTAL   55LA075
CONTINENTAL   5921
CONTINENTAL   6585921
CONTINENTAL   CT652
DAYCO   148S190
F MOGUL TRW   48-17522
FAI AUTOMOTIVE   41148
FIAT   4201738
FIAT   4201739
GATES   5022
GEMINI   D8052
GOODYEAR   148LH190
GOODYEAR   2455420
HAVAM   VS9101
HUTCHINSON   148AX3/4"
HUTCHINSON   41148X3/4"
HUTCHINSON   555LA075
KLEBER   1148190
LUCAS   KCB115
MITSUBOSHI   148ZA19
MOTAQUIP   VTB122
OPTIBELT   41148X3/4"
QUINTON HAZELL   QTB123
ROULUNDS   148TP190
SEAT   GC01201200
SEAT   GC01201201
SEAT   X042017390
UNIPART   GTB1022
UNIROYAL   41148X3/4"
1.8 146 Tooth
A E AUTOPARTS   TB113
BANDO   146ZA19
BOSCH   1987949030
BOSCH   9144161146
COLMANT CUVELIER   091R190
COLMANT CUVELIER   146R190
CONTINENTAL   547LA075
CONTINENTAL   5918
CONTINENTAL   6565918
CONTINENTAL   CT649
DAYCO   146S190
F MOGUL TRW   48-17505
FAI AUTOMOTIVE   41146
FIAT   4164869
FIAT   4182426
GATES   5005
GEMINI   D8051
GOODYEAR   146LH190
GOODYEAR   2454620
HAVAM   VS9098
HUTCHINSON   146AX3/4"
HUTCHINSON   41146X3/4"
HUTCHINSON   547LA075
KLEBER   1.146.190
LUCAS   KCB104
MITSUBOSHI   146ZA19
MOPROD   MTB11
MOTAQUIP   VTB105
OPTIBELT   41146X3/4"
QUINTON HAZELL   QTB110
ROULUNDS   146TP190
SEAT   FC01201202
SEAT   FC01201203
SEAT   X041648690
SEAT   X041824260
UNIPART   GTB1005
UNIROYAL   41146X3/4"
1.4 144 Tooth
A E AUTOPARTS   TB112
BANDO   144ZA19
BOSCH   1987949029
BOSCH   9144161144
COLMANT CUVELIER   144R190
CONTINENTAL   2631540075
CONTINENTAL   540LA075
CONTINENTAL   5920
CONTINENTAL   6585920
CONTINENTAL   CT651
DAYCO   144S190
F MOGUL TRW   48-17504
FAI AUTOMOTIVE   41144
FIAT   4152329
FIAT   4182415
FIAT   4182425
GATES   5004
GEMINI   D8050
GOODYEAR   144LH190
GOODYEAR   2454220
HAVAM   VS9095
HUTCHINSON   144AX3/4"
HUTCHINSON   41144X3/4"
HUTCHINSON   540LA075
KLEBER   1144190
LUCAS   KCB103
MOPROD   MTB10
MOTAQUIP   VTB104
OPTIBELT   41144X3/4"
QUINTON HAZELL   QTB109
UNIPART   GTB1004
UNIROYAL   41144X3/4"
Title: Re: cambelt
Post by: rossocorsa on December 18, 2011, 11:58:53 PM
there is a Renault belt with the same teeth count but nearly 1 inch wide not sure if it has same teeth profile as beta though anyone know?
dayco 94600  http://dayco.universalautomotive.com/uploads/2009/09/Technical-Information-019-_09_GB-VOLVO-KTB185.pdf (http://dayco.universalautomotive.com/uploads/2009/09/Technical-Information-019-_09_GB-VOLVO-KTB185.pdf)
Title: Re: cambelt
Post by: Thotos on December 19, 2011, 02:06:43 AM
Guy Croft can supply 1 inch wide belts for the twin cams.
Title: Re: cambelt
Post by: rossocorsa on December 19, 2011, 09:05:41 AM
yes but us sad cases like to know more!
Title: Re: cambelt
Post by: 75coupe on December 19, 2011, 11:53:03 AM
The Dayco 94600 belt is for a Volvo S40 and has a rounded tooth form similar to the later Fiats and most other late car manufacturers - this design is better than the "square" early design on the Beta - the belt does not stick in the notches of the pulley as it goes round.
I too have yet to find the mythical 1" belt, and I have contact with a few belt suppliers in my line of work...
Merry Christmas!!!!!
Title: Re: cambelt
Post by: WestonE on December 19, 2011, 12:20:01 PM
Chaps
Once again no mystery involved just pick up the phone and ring Guy Croft he does not bite unless of course you want to "Slap a Turbo on it Mate". As he is an ex chief engineer from a Turbo engineering business he tends to have no time at all for reckless stupidity. However he will support mere mortals trying their best to get it right and why spend loads of time trying to find something someone far better inforned has already sourced?
Title: Re: cambelt
Post by: rossocorsa on December 19, 2011, 08:31:36 PM
Some of us are just anoraks and just like to know stuff in some cases this can save cash too but agreed not in this case
Title: Re: cambelt
Post by: HFStuart on December 19, 2011, 10:26:26 PM
Eric,
I'm buying a load of bits and or work from Guy at the moment. In fact I spoke to him today. I could just ask about the belt but where's the fun in that?
Anyway the main point of the post is that I now have just about every reference for the standard belts I'm ever going to need!
Stuart
