Title: Door Hinges Post by: Neil-yaj396 on July 27, 2011, 07:06:02 AM Can the Door hinges on the Coupe removed from the door frames without de-skinning the door? If so how do they come off?
Title: Re: Door Hinges Post by: spud on July 27, 2011, 07:47:16 AM I don't know how far on you are with this but If you remove the door card trim panel you'll be able to see where they bolt on. With sensible hex heads I hasten to add, not the stupid Pozi heads that are a nightmare to remove after 20+ years. How or whether the hinge removes from the door I don't know, never tried, but I would assume they would. Then again...
Andrew. Title: Re: Door Hinges Post by: Momotombeta on September 26, 2011, 03:45:33 PM I donīt know if it is possible, but check this pictures and maybe you can find how.
Regards https://picasaweb.google.com/ch.cruiser/LanciaBeta# Title: Re: Door Hinges Post by: HFStuart on September 26, 2011, 06:29:58 PM Yes they do come off as described and it's pretty simple. If the worst come to the worst and you shear a bolt head off (pretty unlikley TBH) the hinges a chunky enough that you can re-tap the holes easily.
