Title: Injector Post by: cheeky monkey on June 19, 2011, 09:50:03 AM Hi
i'm running through some checks to cure a spluttering/hesitation problem. Is the pump injector a push fit.? i just wanted to check/replace the "o"ring. The top of the carb is off and i'm taking out the jets screwed into the centre body for cleaning but wasnt sure about tackling this injector many thanks G Title: Re: Injector Post by: cheeky monkey on June 20, 2011, 11:02:53 AM forgot to say. its a weber 32 dat
Title: Re: Injector Post by: rachaeljf on June 21, 2011, 12:00:26 AM As I recall it just pulls out. It's retained by the two halves of the carb screwed together.
Cheers R Title: Re: Injector Post by: cheeky monkey on June 22, 2011, 09:19:43 PM Thanks.. it did pull out and all looks fine
the amount of dirt I got out elsewhere was unreal so i'm hoping thats been the main cause. cheers G |
